跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
146 个问题 查看全部
Broken keyboard on the new MacBook Air 13 due to water
I spilled some coffee accidentally on the keyboard, and now 10 keys dont work on the left side of the keyboard, all the other keys work, but its hard to not be able to press all the letters.
Is there a way to replace this keyboard? Where can I buy the part online?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
I think your best bet is to follow the guide to remove the top case. It appears to me that the procedure exposes the back of the keyboard and should allow cleaning to possibly restore full function to your keyboard. While you have it apart please do a complete cleaning of all the parts of the computer. Be advised the author of the guide list this procedure as VERY DIFFICULT. If cleaning fails you may need to replace the top case. Good luck.
MacBook Air 13" Late 2010 Upper Case Replacement
Electronics Water Damage
这个答案有帮助吗?
得分 4
6条评论:
Hi rj713, I was wondering if I can send you a new top case and my MBA, if you could perform the repair for a fee? Thanks
完成的
Hi, I'm not set up to do the quality work you require. If you want to talk to a working tech I would suggest you contact either mayer or rdklinc. You will find their email data on by clicking on their avatar. Good luck.
完成的
+ Thanks rj, I'd be glad to handle it.
完成的
Hi Mayer, I sent an email to you a few days ago did you get it?
完成的
I'm not sure, are you Larry?
完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
Here's the guide for doing this yourself: MacBook Air 13" Late 2010 Upper Case Replacement
It is pretty involved. Are you sure that's all that's wrong with it. iFixit doesn't actually do repairs, they just show you how. But there are some professionals who contribute answers for them. They are not affiliated with iFixit. You can go to Users to find one. Click on their icons to see if they are pros and where they are located. I'm one such person and others may make a post who might be willing to do this for you. You can then email them if you find one you like.
UPDATE 8/25/11
You now hold my record for the farthest away repair I've worked on. Shanghai to Lubbock, TX is quite a distance. I just got in the new Pentalobe screwdrivers from iFixit to do the repair. Do I need to order your part or will you have it shipped to me.
这个答案有帮助吗?
得分 5
2条评论:
Excellent decision to sent it to you all the way from Singapore. Your reputation precedes you ......:-)
完成的
I guess I did it right, it didn't come back and the PayPal went through. It did cost about $55.00 to FedEx one way.
完成的
添加一条评论
To check out if anything else was damaged please hook it up to an external keyboard.
这个答案有帮助吗?
得分 2
添加一条评论
此回答最初是针对另一个问题
I had this problem (spilled some beer on a 3rd-gen MBA keyboard) and sent it to Richard Mayer (above), who did an excellent job replacing it.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Sam, it was a pleasure to work with you.
完成的
添加一条评论
I did the same stupid thing, spilled liquid into the keyboard.
Sent it to the Mac dealer for an estimate, they claimed it would be too expensive to repair, since the battery, top case with keyboard, touchpad and possibly other parts needed to be replaced.
Everything except a number of keys on the left side seems to be working 100%. When performing an Apple Hardware Test (pressing D while booting, I had to plug in a USB keyboard to do this since the D key is one of the missing ones), no errors or problems were reported!
I openend the *@$$ thing (using a non Pentalobe screwdriver so I destroyed some of the screws) and cleaned the keyboard and touchpad by running a lot of warm water through them, then let the parts dry overnight. After reassembly no improvement (but not worse either). It seems the keyboard signals pass through the touchpad, and I suspect that some of the IC's on the touchpad has been fried, so I would like to replace this, but the Apple dealer in Norway say they are not allowed to sell spare parts. Any idea where I could find this spare part ?
这个答案有帮助吗?
得分 0
1条评论:
I got mine from www.Welovemacs.com
完成的
添加一条评论
添加你的答案
apricotscrub 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 14,070
