跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
184 个问题 查看全部
Should I replace the glass, the digitalizer, or the whole phone?
I cracked the glass on my S8 edge forever ago…it was pretty bad but it was tolerable I could still see everything…it got dropped or fell a few more time, the last time this happend it got a much deeper crack and the screen doesnt work. 75% of the screen is white and I can't see anything for the most part however the screen still responds to my touch. The phone still totally works when I touch the screen, it can still run whatever program I open but I can't see anything. I went to my local repair shop and it was going to be much more expensive than I thought. I'm not sure if I should replace the glass or the whole setup….any advice?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
You’ll have to replace the whole display. Replacing the glass would do nothing for your image. The amoled panel is broken. Also, most repair shops quote for a whole display regardless if the amoled panel is working or not because it is almost impossible to replace the glass on Samsung curved displays.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brianna N 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 18
