跳转到主内容
非一体化电脑称之为台式机。
1152 个问题 查看全部
What does this description mean?
Replace a broken or malfunctioning (MSi) RX 480 graphics card in your desktop to fix overheating issues or to restore gaming resolution.
Does it mean it still works or is it broken?
The item code is: IF253-060-1
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
2个回答
最有帮助的答案
Might also want to check that both fans installed on the card are working.
这个答案有帮助吗?
按维修分数 2
添加一条评论
Try lifting out and re-seating the card in its slot.
Try uninstalling and re-installing the driver for the card.
Note: You might try using DDU_Display Driver Uninstaller app to completely remove all traces of old, possibly corrupt driver.
If neither helps then replace card.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Zeus x 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 25
