跳转到主内容
Repair guides and support for drywall and plaster construction.
7 个问题 查看全部
Can you paint over intumescent paint with regular paint?
I have a steel beam in my new kitchen which I want to leave exposed. It already has been covered with intumescent paint. Can I paint over the intumescent paint for decorative purposes with regular paint? Or does it need to be some kind of intumescent paint? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@anna_asking this is a big depends answer. Intumescent paint is applied intumescent paint on the steel beam to protect it and obviously your building, work from the effects of fire. You would need to know the composition of it and then possibly contact the manufacturer of that particular paint. Some let you paint over it, others do not. Some of the better paint suppliers can also be helpful in determining if you can and may have a product available that would comply with this.
So, can you? Sure. Should you? Depends.
这个答案有帮助吗?
得分 1
1条评论:
Thank you I really appreciate your helpful response ! I will hopefully be able to find out the composition info.. thanks!
完成的
添加一条评论
添加你的答案
anna_asking 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 53
总计 2,887
