跳转到主内容
修复你的物品
维修的权力
商店
Why is my MacBook Air stuck on all caps after top case replacement?
So first of all, I spilled juice on my MacBook Air (A1466) 2 months ago. I cleaned up the motherboard after about a month of not using it, and it started booting up. I could log in as guest, but I couldn't log into my main account because everything was in all caps, I couldn't get any numbers or lowercase letters.
I then replaced the top case, but kept the track pad from my water damaged one, because it still worked. However, after the top case replacement, it is still stuck on all caps. The caps lock button itself seems to function normally, but it has no effect on what's being typed. I tried using the keyboard viewer, but even that types in all caps, even if caps lock is not on and the shift button isn't pressed. Is there anything I can do to fix this and be able to log into my MacBook?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
2个回答
最有帮助的答案
Sorry guy, Yull need to replace your trackpad MacBook Air 13" (Mid 2013-2017) Trackpad and here’s the guide MacBook Air 13" Early 2015 Trackpad Replacement
The trackpad is also the junction point for the keyboard signals and where the decoder sits. As you have already replaced the keyboard it can only be the trackpad that the decoder logic has a problem.
MacBook Air 13" (Mid 2013-2017) Trackpad图片
产品
$89.99
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
In this case, if the keyboard sort of works, I’d advice to do a SMC reset and PRAM reset and see if it will let you do these two things. Also, try an external keyboard to login to the main account and see if you can now type in the password. If you can login, I’d suggest to do a backup of all of your data and then try to troubleshoot again in case something breaks.
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jose Ramos 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 7
过去的30天: 36
总计 819
