跳转到主内容
修复你的物品
维修的权力
商店
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
153 个问题 查看全部
Why won’t my laptop charge?
My laptop shut down (low battery) and when I try to charge it (tried to wait for 30 min) it only shows the low battery screen with the connect to power symbol. Charger kept sparkling when put into socket, plastic not melted but metal prongs slightly melted (edge part a bit rough). Is the problem with my charger?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Are you using the original charger and USB-C cable that came with your system?
完成的
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
2个回答
最有帮助的答案
The MagSafe port is magnetic. Visually examine it as it can pick up small screws, staples, etc and short the charger out.
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
I’d advice you to try to use a different charger and see what happens. Meanwhile, try to move the charger adapter around and see if it starts to charge it. If you get the computer to start charging try to do SMC reset and PRAM reset and let us know what happens.
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bianca 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 55
