跳转到主内容
修复你的物品
维修的权力
商店
The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
25 个问题 查看全部
Can I fix my broken charging port?
My charger port inside my tablet either doesn't charge my battery or the screen doesn't want to turn on. When I plug it into my power bank, it does not withdraw power.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
if you have a soldering iron and the port is just loose, just solder it back together, however if it is damaged you will have to buy the port off of ebay or someplace like that f you think if you have the skills to repair it. however if you dont, i advise you bring it in to a repair shop
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
FaserGamer 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 68
