MacBook doesn't start on AC
Hi there,
my 2Ghz C2D Macbook doesn't start anymore. What happend is that my charger imploded during the charging process of the Macbook.
What I tried:
AC Yes / Battery No / Macbook => No :-(
AC No / Battery Yes / Macbook => Yes :-) / Charging => No :-(
AC Yes / Battery Yes / Macbook => Yes :-) / Charging => No :-(
What could be the problem? Logicboard? Megasafe Board? another connection?
UPDATE(!): Changed the Magsafe Board. Now it does work connected to AC or to a charged battery. But still not charging. So. I either use it on AC or on battery. But can't get the battery charged. Suggestions?
4条评论
Did you replace the MagSafe adapter. Please explain this implosion
由 mayer 完成的
Didn't do anything till now. Should I try changing the adapter first?
Implosion:
My original Apple charger was broke and I bought several months ago another one on amazon for 29 EUR (non-apple). It worked well until 2 days ago. I plugged it in but the light didn't went amber. So I looked more carefully and recodnised that the charger looked weired (One black cable was looking out). I played with it (still plugged into AC and Macbook) and it just imploded (*bzzz* - *boom*). After calming down I went back to the macbook (I did jump to the other site of the room, after the *boom*) and checked if it started. But my battery was empty so I couldn't test it. Until today. I went to the apple service and tested it there.
由 Memo 完成的
I can't tell if you're talking about the MagSafe adapter or your MacBook. What was the result of your visit to Apple? Did they test the adapter? Did they test the Book?
由 mayer 完成的
First they connected the macbook with a charging cable and removed the battery. Macbook didn't start and no light indication. After that a fully charged battery was inserted and the Macbook unplugged from the charging cable. Macbook started as usual. Works. But OSX says Battery at 0%. Charging cable plugged in and no light indication. Macbook still runs on battery.
由 Memo 完成的
