Replace Face ID, sensor flex and logic board on a doner phone.
My iphone XR TMobile Black was destroyed via a hammer (long story). It doesn’t even turn on even if I connect the charging cable or to my MAC. I looked inside and it the “Front Sensor and Speaker Assembly Flex Cable”, “Front Camera and Infrared Assembly” and logic board are unharmed (I am assuming from visual inspection). If I buy a donor iPhone and change the above three components will it work (theoretically)?
1条评论
What got hammered? if it doesn't turn it then it may need logic board repair. Keep in mind this iPhone will never be the same again, in iOS 13 they put several boobytraps that will throw off all sorts of warnings when you disconnect parts.
由 Jimmy James 完成的
