跳转到主内容
Updated version of the Kindle Fire 7" tablet by Amazon with 1280x800 HD display. Released September 2012. Repairing this device is straightforward.
101 个问题 查看全部
kindle is bricked, pc shows tate, but cant get adb to work!
hello
i have a kindle that needs a new firmware, along the path of fixing i made a fastboot cable, pc wasn’t able to detect the device at first however, if i push the plug into the kindle, it gets recognized as tate pvt 8, which is good but when i use the adb drivers for it, i get “this device cannot start error 10”, im going to try on a fresh install of windows then linux, if the problem persists i may change the usb port
whats ur input, will this be useful and not a waste of time ??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had to look up fastboot cable. Read your original post also…. Looks like you got the cable working already on the android side. I have had better luck using adb on linux PCs instead of having to mess with windows USB drivers. Others will no doubt have other opinions. Also noticed that some folks opinion is that an incorrectly wired fastboot cable can cause damage that is more difficult to fix … rendering reflashing with said cable impossible perhaps.
这个答案有帮助吗?
得分 0
1条评论:
well, i get to the fastboot mode alright, i get the pc to recognize it but i get stuck at, this device cannot start, i tried on a fresh install of windows xp, it didnt work i have linux downloaded i will try it and get back to ya, thanks alot
完成的
添加一条评论
添加你的答案
I Understand I Exist 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 332
