跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Power led blink and the Mac won't start
Hi.
Some week ago, my Mac started facing the following problem.
When I try to turn it on the power led blink, but it doesn't start (nothing at all)
When I take the power cord out for a couple of hours and plug it again, the computer starts normal and can work for hours with no issue.
I’m guessing it the battery, power supply or the board if someone had seen this behavior and fixed it would appreciate any hints
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I would start things off by running the onboard diagnostics to see what it pops for an error. Restart your system and press the ‘‘‘D’’’ key. Did you get anything?
You are likely hitting a low or dead PRAM battery. If you leave your system unplugged or use a anti-vampire power strip/surge suppressor you can encounter this. FYI: The PRAM battery is on the backside of the logic board
这个答案有帮助吗?
得分 0
添加一条评论
See the answer here for "Mac Mini won't turn on" answered on June 10, 2022. It's probably what you (and I) have.
这个答案有帮助吗?
得分 0
1条评论:
Becareful! There are two versions of logic board here one with a discreet GPU and the other only offering the integrated Intel CPU graphics engine.
完成的
添加一条评论
添加你的答案
Aviv Waiss 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 274
