跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
Logic board compatibility 30GB in 60GB
I have an Ipod Classic 5th Gen A1136 and I pulled the battery connector from the logic board while removing the cable. That’s what you get for rushing :) I am wondering if a logic board from the 30GB Ipod of the same generation will fit into mine ? I believe that the 30 and 60GB use the same early board and are compatible but prefer to check before purchasing the 30GB one. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@pedro147
yes it does. no issues there.
这个答案有帮助吗?
得分 1
4条评论:
Man that was quick, I hadn't even logged out yet @oldturkey03 :) I was just reading about some HDD upgrades as well and you have contributed some valuable answers there too. I thank you and have a great weekend.
完成的
@oldturkey03 if you are still around, I was just thinking that seeing as the Ipod I might buy appears to have a better LCD screen than mine, can I just put my 60GB HDD straight into it please ? I would assume so from what I have read here. Thanks.
完成的
@pedro147 yes you can. If your original iPod was a 60GB you are okay, if it was a 30GB you need a thinner battery (the one for the 30GB is thinner so stick with it)
完成的
Thanks again @oldturkey03
完成的
添加一条评论
添加你的答案
Peter Newman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 239
