跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
问题已关闭
Can I replace a iMacIntel 17 optical drive with a 2nd HDD?
Can I replace a iMac Intel 17" optical drive with a 2nd HDD?
I would want 1 ssd sata and 1 Hard disk 2.5 (sata o pata?)
Bus ATA:
MATSHITACD-RW CW-8124:
Modello: MATSHITACD-RW CW-8124
Revisione: DACH
Numero di serie:
Unità amovibile: No
Protocollo: ATAPI
Numero unità: 0
Tipo di socket: Interno
Polling a bassa potenza: Sì
Spento: No
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, you can have a second drive by using a Optical Drive Adapter. You can have either a one ssd sata or one Hard disk 2.5, you can't have both. Please give us the last three figures of your serial number (found on the bottom of your stand) so we know exactly which machine you have and direct you to the correct part.
这个答案有帮助吗?
得分 1
1条评论:
excuse for my very bad English.
I would want 1 ssd (64Gb) to the place of the 3,5 hard disk and 1 Hard disk 2,5 to the place of the optical unit
The serial number is: CK720027WH4
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 437
