跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Samsung Galaxy s6 Won't Charge
I dropped a Samsung Galaxy s6 in a sink filled with water, and pulled it immediately. I didn’t even try powering it up, ordered a replacement battery and worked on disassembling it. The little Ifixit heating pad didn’t work at all; a careful application of my heat gun did the job easily. Replaced the battery and carefully cleaned all the internal connection points. Also unplugged all the internal connectors to the motherboard and cleaned everything with acetone. Put everything back together, and it won’t charge, at least according to the charge indicator LED. I’m equipped to do surface-mount work, but replaced the entire motherboard instead. Also carefully cleaned the micro-USB charge port. Still no indication of charging. Any ideas?
Thanks,
—Pete Young
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@peteyoung this “but replaced the entire motherboard instead “ and this”Replaced the battery “ and still not charging makes me think you have a bad daughter board. Replace it 更换三星盖乐世S6的子板 and then re-evaluate.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peter Young 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
