跳转到主内容
修复你的物品
维修的权力
商店
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
150 个问题 查看全部
Checking battery health before replacement
I followed Ifixit guide to remove batteries unit from first generation apple ipad.
Is there a way how to check their health (see pics)
as I couldn’t on the ipad as completely dark and did not open, before I purchase another unit, pls?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
1个回答
已选择的解决方案
All you can do is test battery voltage with a multimeter or a DCPS to see if it’s still alive. Ideally voltage should be around 3.8/4.2v range if it was charged recently. As for other indepth info like number of charging cycles or possible failures, unless one has dedicated battery testing tools, battery should be up and running into a device.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alfred Briffa 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 55
