跳转到主内容
Laptop won't power up and no light on charger
Hello
I'm trying to sort a problem with a 2010 macbook pro.
There are no signs of life at all. No light on the magsafe charger or nothing happens when you try to turn it on.
I've tried a new magsafe charger, a new magsafe connector on the laptop and also put new batteries in it and it still won't boot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sounds like it’s a problem with the dc-in power jack. Thankfully your computer is simple to disassemble. just follow these steps until you get to 4:50 in the video then simply unplug the dc-in power board from the motherboard: https://youtu.be/3RhlD-TMHCg?t=45
Here, I even found a replacement power board jack for you: https://tinyurl.com/y334qyrp
gl hf!
oh, also remember to either wear rubber gloves, or a static discharge wrist band. static can do more harm to your computer than you.
这个答案有帮助吗?
得分 0
3条评论:
Tried changing that but didn't fix it, also there is no battery indicator working when I installed the new battery, surely there was some charge on it from new
完成的
"surely there was some charge on it from new." True, then it sounds like there's a problem with one of the parts on the motherboard used to manage the power input. Sorry to say, but you may need to replace the motherboard.
Then again, there is another, possible, solution. There could be a cracked solder joint on one or more of these parts on the board. With that in mind, you could try using a heat gun on the board. However, this does come with a risk. it could overheat a part and damage it. You'd have to be very care full if you attempt this.
I've got to go to work now, so I probably won't see your reply until tomorrow.
完成的
I did take the logic board out but nothing seems damaged or burnt. Not even that much green stuff on it
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 48
