跳转到主内容
数百个光盘驱动器的维修指南。
30 个问题 查看全部
Is this drive look nonstandard?
Individual drive:
Compared to a normal IDE laptop optical drive:
Since my primary external drive is one of those with a soldered USB port (and is a throwaway when it fails), I found two laptop optical drives that I haven’t used in years - one of which is a HP Lightscribe drive (I know the LS functions aren’t really practical today, but it will work as a standard burner) and a drive I pulled from an T43 that was a parts machine. The IBM drive is the one I don’t know if this is standard or one of the many nonstandard connectors IBM has created. I think it’s nonstandard because it doesn’t look right (and it’s an IBM drive), but I have also read this is a standard IDE drive (UJ-822B) so it may be a hotswap friendly connector based on the IDE specification - I’m not entirely sure.
Is this drive look like a standard IDE drive I can get an enclosure for (albeit hard to find) or is it look like it’s a proprietary IBM part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
They are both non-standard. This is the one I would look for:
这个答案有帮助吗?
得分 2
1条评论:
The HP drive (bottom) is standard IDE. They didn't do anything special to the drive like IBM may have.
完成的
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 162
