跳转到主内容
Game Boy(Game Boy 掌上游戏机)于 1989 年 4 月 21 日在日本发售,随后在 1989 年 7 月 31 日登陆北美地区,最后于 1990 年 9 月 28 日在欧洲上市。它的特点是拥有一个较大的灰色外壳,型号为 DMG-01。
My Gameboy Cartridge dosn't work
I just bought a original Gameboy Cartridge of The Legend of Zelda Links Awakening. The Screen of my Gameboy only shows this, while other games run flawless:
I can’t see a single problem it the cartridge itself, cleaned the contacts, tried a new battery - nothing works. Please help me, im clueless.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It’s always possible those resistors blew. You’d have to use a multimeter to test them though. You’d have to determine the stripe color resistance(the stripe rings tell you how many ohms of resistance they should be). If the resistor blew(open lined meaning no connection from side a to b),or if it lost its resistance and shorted(basically now it’s a wire and has barely any resistance for electricity to flow)..this could cause issues.
But if an ic chip goes bad,it really can’t be fixed,Only replaced. Unless you’re advanced in electronics and soldering,you really should buy a new cartridge.
这个答案有帮助吗?
得分 1
1条评论:
On Gameboy and Gameboy color games the solder joints often fail because the pcb is too thin and flexes when the cart is inserted, which has similar symptoms to a bad IC but is much easier to fix. They can often be fixed by just reflowing the solder on the legs of the ics. Doing this requires a lot of flux and a soldering iron with an appropriate tip (knife or J tips work well), but isn't terribly difficult.
完成的
添加一条评论
添加你的答案
silvergame 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 1,887
