跳转到主内容
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
140 个问题 查看全部
My MacBook Air hasn’t been turning on in 3 days! Please help!
On Saturday morning I woke up and my MacBook wouldn’t turn on. I’ve tried smc and pram resets already but nothing seems to be working. The only cause I could think of is that I spilled a bit of water on the touch pad but it should have dried up by now. I’ll attach a picture under the cover of it. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It doesn't take much ;-{
Tap water is not clean! It has minerals and salts which are still present on the surfaces after the water has evaporated. Bottled spring water is often heavy with minerals!
完成的
添加一条评论
1个答案
最有帮助的答案
Given where you spilled I suspect the Touchpad got wet and the corrosion maybe limited to it. Here’s the needed part MacBook Air 11" (Mid 2013-Early 2015) Trackpad and here’s the guide you’ll need to follow MacBook Air 11" Early 2015 Trackpad Replacement
I would start there
MacBook Air 11" (Mid 2013-Early 2015) Trackpad图片
产品
$109.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aaron Quan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 74
