跳转到主内容
The HP ProBook line of business laptops was released in April 2009, aiming to be a lower cost to HP's EliteBook lineup.
237 个问题 查看全部
Will I lose my files if I hard reset my pc
I've been reading about this hard reset procedure as a fix for “black screen of death” by simply removing your battery, charger and whatever peripheral device you have connected, by hold the power button for 60 seconds then plug in the charger and switch on your computer.
But I have to ask if I do this will I lose all my files because I don't have them backed up…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
2个答案
最有帮助的答案
If the system is properly turned off you won’t loose what is stored on your SSD or HDD drive disconnecting the battery.
这个答案有帮助吗?
得分 2
添加一条评论
You probably won’t lose all your files because removing the battery doesn’t affect the nonvolatile storage of your hard drive.
That being said, if your computer is giving you issues, it is always best to have a data backup just in case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ebahi Agoni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 130
