Capacitor replace, original 27000uf 80v replace with 22000uf 105v
Hi
I got a Sherwood AX-9030 amplifier with two big 27000 if 80v caps, which have seen better days. Left channel is lower volume untill the main volume gets turn up and down again.
So, can I replace the 27000uf 80v caps with 22000uf 105v or 33000uf 63v caps? As these are the only ones that will fit (51mm x 105mm).
