跳转到主内容
An HP desktop computer released in 2008.
12 个问题 查看全部
windows could not update the computer's boot configuration install...
My Pc is a HP Elite 8200, It’s not specified on the website
I tried updating to windows 10 Via a USB Stick.
Everytime I do I get the error message “windows could not update the computer's boot configuration installation cannot proceed”
I have gone into CMD, cleaned, formated, coverted to GPT. and still nothing. I took out the other HDD, Nope.
I tried disabling Secure Boot… or launching EUFI via BIOS Launch etc, I have some EUFI Utillity Launcher to my Boot USB, They just access the files or somthing.
I’ve tried everything and it just won’t work :/
At the Moment I’m stuck in a Update Windows Limbo, I’ve formated the Drives many times.. so Windows 7 is gone. -_- I’m thinking my PC is only Legacy… I might have to go back to Windows 7, somehow install this EUFI thing… Any help would be much appreciated, I’m usually handy with this stuff.
Cheers in advance :)
Update (10/02/2019)
I Installed Windows 10 On an SSD and put that into Sata, Boots off that and it Worked, Cheers for the help guys :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Known Specifications:
CPU: I7 2600
RAM: 8GB
GPU: Nvidia GTS 450 (1gb)
STORAGE: 1.7Tb Split between 3x HDD
完成的
添加一条评论
2个答案
已选择的解决方案
The only place where you can download Windows 10 safely is directly from Microsoft’s website because Windows is proprietary software. Please download your Windows 10 ISO from Microsoft.
Windows 10 works best with a GPT-formatted hard drive, UEFI mode, and Secure Boot enabled. Please verify all these settings before proceeding with your installation.
You may be correct about your hardware being legacy hardware. Windows 10 requires a CPU with PAE, NX, and SSE2 technologies that Windows 7 does not need. If installing Windows 10 proves impossible, you may have to reinstall Windows 7.
这个答案有帮助吗?
得分 2
添加一条评论
Try this :
Also refer to these websites to learn more about your problem.
Microsoft
The Windows Club
这个答案有帮助吗?
得分 1
4条评论:
I'll try this, How trusted is that site?
完成的
And as I said I can't access the UEFI Boot Options
完成的
You can trust the website I used it many times and someone in Microsoft community suggested it to me, why you can't access BIOS settings?
完成的
I could access BIOS Just not any UEFI Settings
完成的
添加一条评论
添加你的答案
Brayden Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 65
总计 7,434
