跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Black dots on camera image, new camera and lens replaced still there
Hi all, as title explains. My Samsung S6 camera has permanent black dots on the screen. Only when camera app is on though. You take pictures and it shows up on the pictures. I cleaned the lens area with an alcohol wipe without realising the lens glass circle had fell off previous, so was cleaning the lens and the camera. After cleaning the camera and lens with a cotton bud the dots were still there, giving me the conclusion the camera was damaged and needed a new one……plus a new lens cover lol.
Replaced the camera with a new OEM camera and also changed the broken lens. Once switched back on the fault is still there with a new camera. Which is making me think its not a camera fault.
Has anyone suffered the same issue after changing the camera and lens and if you were able to find what’s causing it and fixed it how did you manage?
Many Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Is there a pattern to the dots or are they randomly spread across the screen?
Have you tried starting the phone in safe mode (should be the same procedure for your model) and check if the dots are there when using the camera?
If they aren't then a downloaded app is the cause of the problem. The trick is to find out which one.
Final option is to perform a factory restore to determine if it is a hardware problem or not. Be aware that a factory restore (or reset) will ERASE all your data and downloaded apps, so BACKUP the phone BEFORE performing the reset.
Once the phone has been backed up and the reset completed, test the camera.
If the problem is still there it is a hardware problem. As you have replaced the camera components it looks like it is somewhere on the systemboard. No help I know.
If not there anymore, restore the phone using the backup that you made and check again after it has been restored. If still not there then the reset has resolved the problem.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Gillian Newton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 187
