跳转到主内容
加入维修社区 - 创建账户
The iRobot Roomba 880 is an autonomous vacuum released in 2013, with greater power and cleaning capabilities compared to the previous models.
4 year old Roomba 880 squealing while running
UPDATE:
thank you for all your responses we determine that it was the side brush motor. Ordered a new side brush motor and No More Squealing! YAY
Again, thank you all for your help
My 4 year old 880 has starting squealing/screaming while running. I’ve cleaned everything but still scrams. I’m afraid it’s the motor, any suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you! That’s what we were thinking too.
完成的
添加一条评论
2个答案
已选择的解决方案
It’s probably the motor, if you’re an expert, you should take it apart - but for most of the time you should ask the previous owner, or company if they can fix it.
Again, what I always say “look it up!”.
Looking it up might not work…
这个答案有帮助吗?
得分 0
1条评论:
Thanks for seeing this! :)
完成的
添加一条评论
I had a squealing noise in my Roomba too. which I could trace down to the gearing of the extractor brushes.
The motor was slightly displaced so that the gears didn’t connect properly. I was able to fix this temporarily by adjusting the motor with a piece of plastic. but the gears were worn down already so that I had to replace the extractor housing (including motor and gearing). was not a lot of trouble and is totally doable!
I found the housing in the Roomba shop, but it was a hidden link I only found using google… I am not shure what the situation is where you come from but here in Germany this was also the cheapest offer!
这个答案有帮助吗?
得分 0
1条评论:
https://shop.irobot.de/de/cleaning-head-...
thats the part I bought for ~45€ while Amazon and Ebay were >60
完成的
添加一条评论
添加你的答案
SueWormington 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 22
总计 3,153
