跳转到主内容
加入维修社区 - 创建账户
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Engine will not start; does not click when key is turned
Mowing got a strange smell from the mower, smelled sweet. It then cut off and white smoke billowed from the exhaust. Now it won't start when the key is turned, no Idk as well. Looked at the engine and oil was caked all on the sodes and underneath. Dip stick was dry. So it likely seized and is now broken for good, right? Is there any hope of fixing it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I know that blowing an automotive engine will sometimes feature detecting a "sweet" sort of odor, which is actually associated with the coolant in the engine, but don't think that applies here.
Sounds to me that maybe you were losing engine oil from a leak, and ran it out of and/or without oil until it seized. If that's the case, I agree that engine is done.
Try turning the main shaft, using a socket and ratchet (or breaker bar). If it doesn't want to turn, it's likely seized.
Mower itself shouldn't be hurt by the event of engine failure, though. So you could simply replace the engine, if you wanted to keep that mower in service (vs. perhaps buying another mower).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ipate84 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 94
