跳转到主内容
加入维修社区 - 创建账户
JD 2440 tractor, hydrolic fluid leaking from pet $!^& on top of pump.
when I close the pet $!^& I can’t raise or lower bucket, when I open the pet $!^& and let the fluid leak out then I have hydraulics again. The hydraulic resiour was way over filled from this issue? Is there a filter thats blocked? The hydraulic pump must be good or the bucket wouldn’t work when the pet $!^& is opened.
Thanks
Ron
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Petcock is one word not two.
完成的
添加一条评论
1个答案
最有帮助的答案
Some Johne Deere front loaders have two pumps, an OC pump in the belly and a CC on the front it. It sounds like the one of the pumps is not putting out enough or you have contaminates in the priority valve.
Change the filter, remove the priority diverter valve on the left side of the tractor located between your left foot and rear axle make sure everything is clean before during and after.
Disassemble valve you will find a passage with a piston and spring remove and clean it. Remove the spring and put the piston back in bore and see if it moves freely back and forth. Run some 800 grit crocus cloth around piston and in the bore lightly. Clean up and blow out with air. Reassemble spring and piston the way you found them, install on tractor and try.
NOTE do not run tractor for long if the loader is not working this will ruin your front pump.
If this answer does not help go here for a live answer:
https://www.justanswer.com/sip/john-deer...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ron Sullivan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 483
