跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Black tape on logicboard important?
How important is to re apply the black tape on the bottom of the logicboard that covers different intergrated circuits, they are in about 5 places (i.e. under the Airport Extreme Card). thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
I can't speak with certainty on this but my initial feeling is: if you found black tape originally underneath that Airport Extreme Card then I would say go ahead and replace it with the exact same type (there are 2 different types of black tape). Remember, the shinny soft plastic black tape have a very "sticky" adhesive on it and you DON'T want any of that to get into/near any connection points on any part of the logic or I/O board.
Black tape serves and an insolation between electrical components, if electrical metal connectors/wires are extremely CLOSE to any metal body ground an "arc" can occur (depending on the voltage that goes thru that component) which can damage some sensitive components and or cause a SHUTDOWN.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 853
