跳转到主内容
Repair information and troubleshooting for the RCA Voyager III, a 7 inch budget tablet that uses Android 6.0 OS and can access the Google Play app store.
34 个问题 查看全部
How do I get activation code for tablet that wasn't purchased in store
How do I get activation code for my tablet that I got for a gift but wasn't purchased from a store?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论:
I have almost the same problem. I bought a tablet from a friend who purchased it at Walmart for a relative. This person put their email on the tablet and then passed away. The friend cannot locate the deceased person's email address so I can erase it and put my email address in it's place! When I try to set the tablet up. I can't get WIFI to recognize my password. I keep getting the message Authorozation Problem. I have the original sales receipt from Walmart which has the one time Activation Code on the original receipt. How do I solve this problem?
完成的
Exactly what “Key” are you referring to?
完成的
@Michael Tingle I have a similar problem except I don't have the receipt. In your situation you can do a factory reset on the tablet. Google specifically how to do it but it's something like holding down power n volume down key (just make sure first), then wen you see the Voyager screen starting up you let go of power key but continue holding whichever volume key. You'll see a new screen appear, select wipe data factory reset. Wen it's done you can reboot. It will then ask you to enter the activation passcode located on your receipt. That's where I'm stuck. Feel free to share yours so I may move forward as well.. but either way you should be ok after that.
完成的
添加一条评论
4个答案
This is answer to Mike tingles issue. I have a similar problem except I don't have the receipt. In your situation you can do a factory reset on the tablet. Google specifically how to do it but it's something like holding down power n volume down key (just make sure first), then wen you see the Voyager screen starting up you let go of power key but continue holding whichever volume key. You'll see a new screen appear, select wipe data factory reset. Wen it's done you can reboot. It will then ask you to enter the activation passcode located on your receipt. That's where I'm stuck. Feel free to share yours so I may move forward as well.. but either way you should be ok after that.
这个答案有帮助吗?
得分 0
1条评论:
That doesn't do anything if you didnt purchase it at the store it wont work.
完成的
添加一条评论
Speaker spanish?, mi tablet voyager 3 rca RCT6973W43 no enciende, se apago y ya no prendio, ya la resete, ya la cargue,ya cheque voltajes de entrada y de bateria y me da 3.7 volts, no se que mas hacer, ya busque y no hayo una guia de como repararla, gracias por su atencion
这个答案有帮助吗?
得分 0
添加一条评论
If the item wasnt purchased at the store you will never be able to use it
这个答案有帮助吗?
得分 0
1条评论:
I formatted the device and now I opened the tablet and it asks me for an activation code for tablet Voyager3 i need the code
完成的
添加一条评论
How do I get my activation code to my RCA Android tablet
这个答案有帮助吗?
得分 0
1条评论:
I'm trying to get my Android RCA activation code for my tablet
完成的
添加一条评论
添加你的答案
Jamie Andre 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 62
总计 1,034
