跳转到主内容
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
CDMA vs GSM replacement back cover
Whats the difference between a CDMA iPhone and a GSM iPhone back cover? Why is a GSM replacement cover not compatible with the CDMA? Do you thinks its possible to make it compatible by removing some of the mounting clips or something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
To my knowledge they should both be compatible with each other? The only differences in the models are small hardware changes (logic board) and a different roaming frequency. Have you tried a GSM back cover on a CDMA iPhone or vice versa?
完成的
添加一条评论
2个答案
已选择的解决方案
The iPhone 4 GSM and CDMA back covers are different. The mounting frame scew mounts are spaced very differently.
这个答案有帮助吗?
得分 2
添加一条评论
there's no physical difference between 4s and cdma, the difference is in the writing on the back.
CDMA is 2422
4s is 2430
Check us out on SPAM REMOVED
这个答案有帮助吗?
得分 0
1条评论:
jobo, you need to read the question before posting Spam. The question does nowhere mention a 4S. If you want to become a better spammer, you need to learn that the 4S is a GSM/CDMA (remember the term "world phone") Oh my, you still have a lot to learn little grasshopper. Good luck in your other job, hope you are better at that.
完成的
添加一条评论
添加你的答案
Perry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,888
