Best replacement AirPort card?
My MacBook tends to get rather hot, and has often very unreliable WiFi connections.
I've read that other people had similar problems, and that they went away when they put in a new AirPort card.
It seems that there are some cards that go bad without completely failing, resulting in more heat and unreliable operations without complete failure.
So in an effort to improve the situation, I'm willing to try replacing the card.
Obviously, Apple has had a variety of cards over the course of various models, but most seem to be standard PCIe cards, and thus should be possible to use interchangeably.
My quest is of course for the card with the best performance and the lowest power consumption, rather than for a one-to-one replacement with the same model.
I can't seem to find an overview of what cards Apple shipped with what models, which require two and which three antenna leads, and if there are any known incompatibilities with using a newer card in an older laptop.
Any input or link to relevant references would be very helpful.
2条评论
I should add that the A1226 already has a 802.11abgn capable card.
So when I talk about better performance, then mostly in terms of
a) using less power/getting less hot
b) better reach
c) better implementation of the various protocols.
d) better international compatibility (some cards seem to be hardwired to US frequencies, some seem to scan for other networks and decide what bands to use based on what they receive)
Apple keeps changing between vendors: Broadcom, Atheros, etc.
So assuming that Apple doesn't downgrade its WiFi cards and keeps improving the battery life of its devices, I'd guess that what I should like to install is the most recent Apple WiFi card that has the proper size PCIe connector. Not sure if the most recent machines still use separate cards, or if they have the WiFi built right onto the motherboard.
由 rcfa 完成的
+ for a well written and thorough question.
由 Majesty 完成的
