跳转到主内容
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
Why doesn't my tablet boot up?
My tablet will not charge and when I plug it in and turn it on, it just goes to the Samsung boot screen and flashed.
How can I get past this? Or get it to stop flashing. I tried the power, volume up and home button with no results. Is there something else I can try>
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like a bad battery but sometimes if the battery is too flat it will cause this.
So what I do is hold power + volume down + home until you get the text prompting you to go into download mode warning.
Leave it on that screen while plugged into charger for about 30 minutes and that will charge the battery enough to get it on if it is not turning on because it was flat.
Once it's been charged for 30 minutes press the corresponding button to reboot tablet when prompted.
If this is still no good I recommend reflashing the firmware which I will write instructions on how to later when I have time.
这个答案有帮助吗?
得分 1
1条评论:
I did as you suggested and its just flashing real fast. If I unplug it, it shuts down.
完成的
添加一条评论
添加你的答案
Terry Hilsendager 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 241
