跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
RCA LED55C55R120Q Sound, does not display picture but screen “On”
it was working fine when I had brought it home yesterday, but that’s probably because the man who was giving it away said the light would blink once and not turn on, I think it might have “reset” between his house and mine. I was watching a show just fine had no issue until I noticed that this black screen was not part of the show I was watching. I can still hear when I play a YouTube video from my phone to the Apple TV but I think even the Apple TV knows the screen isn’t working because this is the first time I’ve seen the Apple TV play video on my phone and sound on the tv like as if I was casting to an audio source and not an audio/video source. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My RCA same model is doing same thing. I took it apart and am trying to figure out how to post pictures
完成的
添加一条评论
1个答案
最有帮助的答案
@afrenchfrey
start off by removing all input sources. Then remove the power cord. Hold the power on button down for about 30-60 seconds. then plug the Tv back in and only connect one (1) input source. For now try to stay away from anything like APPLE TV etc and use a local source only. Something like a DVD player etc. Let us know what you get.
Not getting video but having sound can be caused by a bad main board, bad t-con board or a bad panel (unlikely).
Update (07/07/2019)
Post some pictures of your boards etc., with your question. also, if you can, include a picture of the label on your LCD panel. Some white screens can be caused by a failed MOSFET on the T-con board.在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
2条评论:
It worked until it didn’t. It should have been displaying that hdmi input sign up top but not even that. As for anything like that I don’t own anything that doesn’t use hdmi. So I still get the same result
完成的
@afrenchfrey since you did not get the HDMI signal from the firmware, I would suspect a bad main board. I'll check to see if this could be a firmware issue and hope to find enough information about it in my manuals. Look slike this model has EEPROM issues....If you can post an image of the label from the back of the TV.
完成的
添加一条评论
添加你的答案
Azu Frey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 2,829
