跳转到主内容
Repair guides for machines designed to move slowly and get big jobs done, including farm vehicles and construction vehicles designed for specialty tasks.
Fuel in motor oil
I got old ford tractor skip loader and I replaced injectors but I'm getting fuel in my motor oil
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The number one cause would most likely be leaking fuel injectors. ... When a fuelinjector is stuck open, the fuel will flood out. Gasoline will definitely get into the oil when this is the case. If the fuel pressure in your car is too high, that may cause gasoline to get into the engine oil.
这个答案有帮助吗?
得分 2
3条评论:
I put new injectors how can they. Be stuck and I took them out not one was wet
完成的
There's no way it can be injectors that's why I'm asking you all
完成的
Read the rest of my answer.
完成的
添加一条评论
添加你的答案
Victor Puentesjr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 197
