跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
107 个问题 查看全部
New Hard Drive making quiet clicking noises, w/ Audio File
Audio File (Original):
https://instaud.io/3TjK
Audio File (Louder):
https://instaud.io/3TjO
Hello! I got a new Notebook (HP Pavilion Gaming 15-cx0402ng) about 2 weeks ago. The drive is making very quiet clicking noises while it’s working or shortly after it stops being used heavily, I’m not entirely sure, but the HDD LED is blinking when it happens.
I’ve already run multiple SMART tests (short and extended), but it always passes.
Could those just be calibrating noises?
There’s no scratching and I’ve noticed no impairment whatsoever. Before getting this laptop I had a Desktop Computer, so I’ve never been so near to the hard drive and the clicking makes me nervous. I’ve already backed up important data.
Sometimes it clicks every few minutes, sometimes it doesn’t for hours or days and sometimes it does it with an interval of just a few seconds
Hard Drive Information:
https://pastebin.com/87wA10gc
Full Smart Test Output (Result: PASSED):
https://pastebin.com/0H0v0fRZ
Edit:
I just noticed that the clicking mostly occurs when the HDD is on low workload. Could it be the heads parking after performing a small operation?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
现在开始购物
iPhone X Fix Kits
现在开始购物
1个答案
已选择的解决方案
This is completely normal, the drive parks the head after no activity for a while.
You can see SMART attribute Load_Cycle_Count, this tells you the cycle number, not sure how to decode this as the number is probably encoded differently, but Load_Retry_Count  is zero, which is good.
这个答案有帮助吗?
按维修分数 2
评论:
Thank you!
I set the APM value higher, so it's less agressive. It stopped now.
添加一条评论
添加你的答案
Florian 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 20
