跳转到主内容
Repair guides and support for your Toshiba TV.
193 个问题 查看全部
Vertical coloured lines on Toshiba TV
Hi, my niece tv has a band of coloured vertical lines on the right side of the tv along with a couple of horizontal lines along the bottom of the screen. The tv is only 2 months old. I have been in touch with Toshiba and sent them photos and they are saying it’s not a manufacturing fault and that it has happened externally. My niece said the lines just appeared and there is no visible damage to the screen itself. I’m would really appreciate a second opinion before I go back to Toshiba. The model no is 43U5863DB.
Thanks
Marie
Update (07/01/2019)
Should also add that the vertical lines do not reach all the way to the bottom of the screen. They seem to start from and reach around a black dot about 2cm from the bottom of the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@reeree29 post some pictures of what you got going on here. This “the vertical lines do not reach all the way to the bottom of the screen. They seem to start from and reach around a black dot about 2cm from the bottom of the screen” sure sounds like a broken screen. Yes, Toshiba is not going to help you with that. You would need to try and find a replacement panel. That size panel is not easy to find and if it can be found will be more than a new TV. If you want to go that route, remove the back of your TV and look at the panel. You should see a label on it. Use the panel model number for an online search.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your help. I have added a photo.
完成的
添加一条评论
A picture might help but sounds like a broken screen so far…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marie Webb 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 42
总计 3,995
