跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
3DS Charging only for a few seconds before promptly stopping.
For details I haven’t use my 3DS for about week or 2 before deciding to play it,
3DS is working fine until I charge it, would only charge for a few seconds and its not even fully charges.
Decided to buy a new charger, same results, change the battery, same results.
Although if I leave the 3DS for a long duration of time take for example 4 hours and proceeds to charge it again, the charging would last more by a minute or more until it stops.
The 3DS recognise that a charger is on it with the battery charging symbol on the top right of the screen but instead of a orange indicator. a blue one appears.
Any idea what’s the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Your chargers are fine. This is a battery problem.
You can read this guide for replacing your 3DS Battery: 任天堂3DS电池更换
Here is a replacement battery: Nintendo 3DS Replacement Battery
If you need any help please reply to this answer.
Thanks,
John
这个答案有帮助吗?
得分 1
5条评论:
I haven't actually brought a new battery, although I have two 3DS batteries (one from the console itself and another from a broken one), decided to swap the batteries same result. I can always try to buy a new battery but that will take time on my part.
完成的
Are you sure both batteries actually work? Is there an swelling on the batteries?
完成的
I actually tried using the my old broken 3DS to charge, its working on both batteries. The problem probably lies on the charging port of my current 3DS or Power receivers... I could always perhaps use my old 3DS as a source of spare parts but I'm not confident with my soldering skills.
完成的
Anyway thank you for taking your time on my problem, sir John.
完成的
I found an article on someone who has had this issue before, which you can find here: My 3ds won't charge anymore
Credit to @lpfaff1 for that answer. Feel free to mark this as answer if this solves your problem.
完成的
添加一条评论
If the battery is fine, check the F2 fuse
这个答案有帮助吗?
得分 0
添加一条评论
Hello, I was having the same issue. I removed the back panel and simply removed the battery, blew off the battery slot, and put it back in. And now it’s working fine. I went for about 2 years without powering it on.
这个答案有帮助吗?
得分 0
1条评论:
Maybe, but it was working like a week before it just wouldn't turn on. I can't try it cause I already sent it to get repaired. Thank you though. I also had gotten a battery and the charge light stayed on but it still wouldn't turn on.
完成的
添加一条评论
remove sd card and game card and retry. same problem for me and the sd card was at fault.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Oliva 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 125
总计 9,757
