跳转到主内容
Repair and disassembly guides for Sony DVD players.
65 个问题 查看全部
Why does my DVD player only play 2 DVDs out of 20?
I have a 2002 Sony 5 Disc DVD/CD Player (DVP-NC615). It has a Precision Drive 2 System.
*Notes.
I have already taken it apart and cleaned it.
I do not have the remote.
Hasnt been used for a few years.
I have tried to play approximately 20 DVDs on it and only 2 will work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Typically this type of behavior is indicative of a failing laser. Try playing a number of standard CDs. If these all work without fail, it suggests that the laser is starting to weaken. If you have already cleaned the lens, then the “simple” fixes have already been applied. At this point, changing the optics assembly is the next step.
这个答案有帮助吗?
得分 2
2条评论:
I would like to note that I think it has to do with the fact that both the DVDs that work have a small "rise" in them. You know when you flip over a DVD and there is a ridge ? Both of these DVDs that work are double sided and play on the side that has that ridge up
完成的
Hi @missfixit90 ,
Did all the discs work before in the unit?
If not, here's a link to the user manual for the player.
Scroll to p.7 and p.8 to find information regarding which discs are compatible with the player
完成的
添加一条评论
添加你的答案
Jess Stevens 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 118
