跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
Ipad won't boot up. Apple logo flashing/bootloop. All help is welcome!
Hi guys!
The ipad pro 12.9”(1st gen) It wasn’t used for over a year. When booting it up after that period, the apple logo appears and disappears a couple seconds after it. This goes on and on. But it will only work when the ipad is charging.
What I tried:
  • Charged for 45min on charger
  • Hard reset, with no luck.
  • Putting the ipad in recovery mode, the itunes logo appears, stays on, but when I want to connect it to the pc it instantly shuts of the display. Pc can’t charge the ipad.
Might this be a battery problem? That the battery can’t hold it’s charge when charging. So the battery is ‘empty’. And there is not enough power to boot it up when connected to the charger?
Thanks in advance!
Nick
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
It certainly appears to be a battery problem. Try keeping the iPad on the charger for 24 hours to see if this helps or not. If you do get the device to boot up, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery. Anything less than 70% of design capacity will require replacement. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging.
这个答案有帮助吗?
得分 3
添加一条评论
I have this exact same problem. How did you fix it?
这个答案有帮助吗?
得分 0
1条评论:
Not, sold it for parts. My guess was that the motherboard was defect.
完成的
添加一条评论
添加你的答案
Nick Schulpen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 8,082
