跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
Why won't my dead iPhone charge?
I dropped my phone in a hot tub recently, but I quickly grabbed it out of the water and dried it off completely. I turned it on and it seemed to be working fine. Then while I was using it, it died. So, I plugged it in, and the little red battery thing came up. So I left it for a bit, and then the apple came up like it was gonna turn on. So I waited and then it turned on for a split second then turned off again. So I waited, but it has now been like 3 hours and it will only show the battery thing. please help me fix it!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If your data (pictures, contacts, notes, messages, etc.) are important to you, and you don’t have an iTunes backup or an iCloud backup, then you should immediately head out to a nearby repair shop and have them lift the screen and disconnect the battery. In the meantime do not try charging it.
Alternatively, you could do it yourself. Follow this link for tools and detailed instructions.
Next, if the iPhone only boot-loops (by turning off then turning on only to show the Apple, then turn off again) when connected to the power charging cable, but stays off when disconnected, you may only need a new battery after be phone board and pars are cleaned and dried.
if it bootloops regardless if connected or disconnected, it may be a number of things.
I personally don’t consider liquid damage repair a DIY thing because you need to lift the shields covering the mother board (requiring special tools and skill), displacing water with a solvent, drying, testing, etc. I would recommend taking it to a reputed repair shop that can perform microsoldering. A lot of them can do it lately, but not all of Ben are yet good at it. Choose wisely.
这个答案有帮助吗?
得分 2
2条评论:
I just saw this and I had kept it plugged in. It turned on and is charging. It is at 57% now and going up very slowly. Do you think I still need a new battery?
完成的
Yep you got that right, I have a co-worker that does the board-repairs / micro-soldering for me.
Myself at best can do charging port replacements with soldering, I'm fairly competent with diagnosing / trouble shooting at a board-level for MacBooks and iPhones.
完成的
添加一条评论
Did you open the phone to dry it out?
这个答案有帮助吗?
得分 0
2条评论:
Not sure what you mean by open the phone up. I took my case off and stuff and tried my best to dry off every hole
完成的
He means opening up the phone to visually inspect the internal components inside the phone. Lots of times liquid is still inside slowly corroding the phone from the inside, like Rany said will require a professional to clean-up the board properly.
完成的
添加一条评论
添加你的答案
Emma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 202
