跳转到主内容
Repair guides and support for a wide range of small engines.
103 个问题 查看全部
Flywheel turns halfway then stops on riding mower
Briggs and Stratton engine model number 33r8770007g1, Craftsman riding mower. Was mowing the lawn and flywheel fan blew up into pieces. Next time I used it it shut off made a popping noise and now the fly wheel only make a half rotation then stop. I checked the battery, selenoid, And starter. They were still good. I took the fly wheel off and changed the fly wheel key and put the fly wheel back on with a new fly will Fan but it still doesn’t work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Todd,
The flywheel blew up? I’d guess that the magneto coil got whacked and moved too close to the flywheel, since it’s only turning half way. I’m hoping you can turn the flywheel by hand and check the gap with feeler gauges or just eyeball it. The new flywheel might be a bit bigger.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Todd benson 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 43
总计 2,587
