跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Tooth missing from new screen home button connector.
Good morning. Yesterday I changed a screen on iPhone 6 Plus. Screen is working perfectly but home button was intermittent then stopped. On closer inspection I’ve noticed that one of the teeth are loose on the connector and has actually snapped but is being held in place by the ones either side. Anything I can do as seller of screen will not refund.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Can you take photos of the home button connector on the screen side and also the home button side (while unplugged?)
Here’s a guide on how to add images to an existing answer:
Adding images to an existing answer
Depending on where it broke, the home button may be able to be reused which is preferred as replacing the home button results in no touch ID / fingerprint unlock functionality.
这个答案有帮助吗?
得分 1
2条评论:
Hi Ben. It’s on screen side only. I have since put original screen back on and everything works fine. Just not with screen pictured. I hope I’ve uploaded correctly.
完成的
To get that fixed it would either require a bit of soldering (a little jumper wire or replacement pin to solder onto that spot or the screen will need to be replaced.
It's probably cheaper to get the screen replaced rather than to have someone re-solder a new pin onto that connector.
From that image it looks like a 6s plus screen.
完成的
添加一条评论
添加你的答案
Karen amatt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 29
