跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1695 个问题 查看全部
PS4 BLOD and it won't go to safe mode
Hi!
My PS4, if i turned it on, everything seems to be working, but it starts to pulsate Blue Light endlessly, nothing on the screen. And if I try to go to safe mode, it won’t. I’m holding power button so long, that it will just shut down and that’s it. Is there any ideas, what could cause all of it? Is it APU or power supply problem? Or something else?
I’m also adding two picture: I disassembled my PS4 and on a quick look, I saw that those areas are a bit different. On motherboard, this RI8H thing seems to be a bit burned or something brown is on top of that? Is that okay, or is it burned?
And also on a disc drive, I found that those two are a bit odd colored as well? Maybe those are the problems?
Every answer or guide will help! Thank You in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
BLOD can be caused by a failing hard drive. Have you tried booting the PS4 without a hard drive installed and see if it gets to the safe mode / cannot start PS4 screen?
这个答案有帮助吗?
得分 2
3条评论:
Tried it, still didn't get to safe mode or no "cannot start ps4" screen. Can it be HDMI or power supply problem? Or APU?
完成的
It'll be the APU in this case. What usually happens is that the APU develops bad solder joints between the logic board and APU.
This can be fixed if the APU is reflowed with a rework station reflow machine which re-melts all the solder joints under the APU fixing up any bad connections between the two.
This will require a reputable console repair store that does console board repairs in order to get this repair done, you may be able to find someone locally in your area that offers this kind of service.
Note that bad solder joints develop on PS4s usually either from overheating (too much dust in the PS4) or the console being physically dropped.
完成的
@benjamen50 Okay, thank You Ben! Will look for a repair service, and let's see how it will go!
完成的
添加一条评论
添加你的答案
Kristo Epner 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 39
总计 8,922
