跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4093 个问题 查看全部
Having an problem to remove 3.9 mm Pentalobe screws its just rotating
Having an problem to remove 3.9 mm Pentalobe screws its just rotating inside not coming out what should i need to do please suggest me thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
Hi,
It sounds as though either the screws, or the slots that they screw into have threaded. The easiest way to remove pentalobe screws when this happens is by doing the following.
1.      Hold the phone right way up, but at a height so that technically gravity will be trying to pull the screws down.
2.      If they have not fell out by this point, then start to unscrew them, as they should loosen up out of the slots, and it will edge them out of the groves.
3.      If after this step, they have still not fallen out, grab a large magnetised screwdriver. I find this step the most effective. I tend to use a Phillips screwdriver the same size that you would use to remove a drywall screw. Nine times out of ten, the screw has always latched onto the screwdriver and pulled straight out.
If there is still difficulties removing the screw, it may be a good idea to try removing the screws, and you are trying to pry up the screen, as the screws may be stuck against an internal part/component that is not allowing you to remove this. Even if this does not work, the best bet may be to either take this to a shop, or have them drilled out.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Roshankumar Patel 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 8
总计 139
