跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
Lines show on TV then it powers down.
These lines appear anywhere from seconds to minutes after the TV is powered on. Then it shuts off. Any suggestions for a DIY fix. I work for a hotel and we don't want to have to pay a TV repair company.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hey Grady, does the TV do this on all inputs? I'm curious if this might be an issue with the cable. Although the TV powering off makes me think otherwise.
完成的
Only on the TV input. And when I change inputs I can no longer go back to TV.
完成的
@acraftyhippo what model is your TV?
完成的
The model is 32HFL5860D/27. It's a hospitality TV. The issue only shows on the TV input for coaxial. If I change the input the problem does not persist but I cannot return to the TV input.
完成的
Out of curiosity, @acraftyhippo, have you tried using a different coax cable, and with that a different wall port?
完成的
添加一条评论
1个答案
最有帮助的答案
@acraftyhippo could be a main board, t-con board or even panel. I’d be looking at the t-con board first. Explain this a bit better “Only on the TV input. And when I change inputs I can no longer go back to TV. “ That sounds like it does not show on other video input sources?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Grady 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 223
