跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
79 个问题 查看全部
MacBook Pro Screen Glitch
I am not sure how to explain this to someone but I have contacted apple and they gave me a few options like reseting the NVRAM and SMC. They told me that if that did not work to go to a store to have to looked at by a professional. I really would like to know what is going on and maybe if anyone has had the same issues. I have added a picture so people can see that is happening to my screen. Also when this is happening I have taken screen shots with the Mac itself and when I do this the screen shot doesn’t show the glitch at all just a normal screen.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
hey have you tried reseting the NVRAM and SMC? is it work?
Resetting the NVRAM or SMC won't alter this.
添加一条评论
3个回答
最有帮助的答案
It’s either a display issue or a board level fault. There is no GPU to fail here, so you can quickly rule that out. Hook it up to an external monitor and see if you run into the same problem to rule out the motherboard. This *is* a USB-C machine and very few people have the adapters on hand - including myself as I don’t have a need yet so keep that in mind when doing this.
There are no mDP to USB-C adapters to use a common adapter anyone with a pre-2016 Mac probably has, so you will need a USB-C to HDMI (or a DVI to HDMI if your test monitor lacks native HDMI), VGA or DP adapter, depending on what level of display you have access to for testing - consumer displays that are relatively modern tend to use DVI, HDMI, VGA or a port mix; legacy monitors tend to be DVI/VGA only. Full size DP is usually only found on professional monitors like the calibrated Ultrasharps or the ASUS ProArt series.
While it’s still best to ask if you’re using someone else’s monitor to test so you don’t waste your time, I’m going to make an assumption you have more access to HDMI then anything with DP, VGA or DVI. Based on that, get an adapter like this and borrow a display from a willing friend for testing, or use it where they are so they can reverse the testing changes. If the display is DVI, that’s okay since it’s more or less similar to HDMI and can be adapted without integrated circuitry or an adapter with electronics; you can use an adapter like this and it’ll work just as well.
这个答案有帮助吗?
按维修分数 1
添加一条评论
Sadly your display is acting up! The T-CON board which is mounted within the main case deals with the raster scan of the display. It’s part of the display assembly.
Think how you weave cloth you have the Warp which are the lines that go up and down and then you have the Weft which goes side to side. In this case the registration of the scan is getting messed up.
You’ll need a new display assembly here’s the guide to get it out 2016和2017款MacBook Pro 13英寸带触控栏版本显示屏更换指南 and here’s one source MacBook Pro 13" Complete Display - Silver (16/17) They also have the space grey as well
这个答案有帮助吗?
按维修分数 1
评论:
Shouldn't this be covered under the extension Apple announced?
Sadly, no... The FlexGate issue was the backlight not the T-CON issue we have here.
添加一条评论
Apple has what is called a flat rate repair.
If your machine does not show signs of impact or water damage, you should qualify.
Call 1-800-MYAPPLE and ask for it. In Texas the cost is $357.00 including tax and shipping.
They FedEx you a shipping box overnight. You put it in and drop it off. Three days later your repaired machine will be back in your hands. If they find anything else wrong with it they will fix that too.
They will need your serial number and a credit card when you talk to them.
One of the few things Apple does that’s really nice, but you have to know to ask for it.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
Kirstie Gaver 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 29
过去的30天: 178
总计 437
