跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1198 个问题 查看全部
X keeps restarting after new charging flex.
Phone keeps restarting after around 3 minutes. Customer came in for charging port replacement. All screws in right place, no long screw damage.
It has had the following to rule out:
Battery and 3 replacement ports. Each flex cable was unplugged one by one to troubleshoot, even with the following unplugged it occurs: Screen Flex (Both), Face ID/Front Cam Flex (All 3), Antenna Flex (Wifi), Lower Antenna, Power Button Flex/Flash & Volume Button Flex & Charging Flex.
I have tried a replacement screen and still occurs. I have checked all the FPC under microscope and very clean and tidy. It cannot be the port surely as it occurs even when not plugged in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
14条评论
Did you find out what the issue was? I did the same repair with the same results.
完成的
I will be grateful for info how did you fixed that issue. Thanks
完成的
How did you fix it?
完成的
In my case the new charging interface was a problem. When I returned to original part with faulty microphone the problem didn’t returned.
完成的
im facing this same issue now on iphone X keeps restarting after charging flex replacement . any solutions please ?
完成的
显示更多的9条评论
添加一条评论
2个答案
已选择的解决方案
Assuming it was working fine prior to your repair attempt, then I would take a closer look at the small components surrounding the connectors. If you see anything dislodged or damaged, then that would probably cause your issue. At this point, you may need to have this looked at by an experienced micro-solderer.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
So apparently after some investigation, this appears to be an issue with 3rd party charge port cables. Apparently in iOS 13+, there is software that monitors thermal readings from the charge port modules and the 3rd party cables do not allow this to happen which triggers a kernel panic, restarting the phone.
这个答案有帮助吗?
得分 4
2条评论:
Is there any fix for this?
完成的
Is their a particular prank or place to look for the replacement that has the sensor
完成的
添加一条评论
添加你的答案
Phone Repairz NE LTD 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 27
总计 6,399
