Is there a larger replacement battery for iPhone 6sPlus?
Is there a larger capacity replacement battery for iPhone 6sPlus?
short answer No there is not. You can Google all day long and will get all kinds of hits that promise some incredible batteries. There are no bigger capacity batteries (nothing that will make a notable difference to your phone anyway). Check the test on High Capacity Batteries on here “大容量”电池的神话
这个答案有帮助吗?
Tip for the Day : Google is your Friend.
Short answer is Yes.
Do a google search and you will find heaps of them on E-Bay and Amazon, but with all things OEM you have to take the risk that some will be great and others will be complete crap. Although I have not used high capacity batteries I have used OEM batteries from China and my experience has been just that, some were good and some not so good.
Good Luck :-)
这个答案有帮助吗?
Thank you,
I found that right after you gave the proper answer, while searching a few different sources. Well, it's lasted over 3 & ½ years, so. I'm grateful. and grateful for your wisdom and knowledge. Give this man the clap! Not that kind you perv's:) A standing 0! Thank you.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 499
