跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
Can I copy OSX10.8.5 to an external drive?
Hi there, I still have OSX 10.8.5 on my internal drive but mostly boot up from an external drive with Yosemite 10.10.5. The only reason I’ve kept 10.8.5 is because of DVD Studio Pro and Compressor, because I still need to author DVD’s and High Sierra won’t allow me to open those apps, and Sierra on an external drive isn’t recognised as a bootable startup. So, am I able to copy my current10.8.5 to an external drive, then update to Sierra or later, and then have the option of rebooting from 10.8.5 on the external drive when I need to, or will Sierra not recognise it. Many thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would use Disk Utilities from my internal drive then erase and reformat the external drive. Use the write zeros option and make on pass to map out any bad blocks on it. Format it GUID. Now install your 10.8.5 on it. Later you can reboot from it, use Migration Assistant to move you data onto it. Now you can install Sierra on it.
这个答案有帮助吗?
得分 5
1条评论:
Thanks Mayer, but I just realised I never had the original disc with Mountain Lion on it as it was already installed when I bought the computer. I suppose I never thought I’d need it because I would always ‘up’ grade instead of the other way around. But thanks for the Migration Assistant tip. I’ve got an old editing mate who’s going to help me and I’ll need to use MA. Cheers, Maurice
完成的
添加一条评论
添加你的答案
Maurice Todman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 40
