跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
393 个问题 查看全部
Apple MacBook Pro - laptop screen cracked
The lower left screen got a hole/cracked - only 15 % of the screen area is effected with left 20% of screen area with lines . Does it need a complete screen replacement or the crack can be fixed . Also, let me know total cost of repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
You’ll need a new display assembly, there is no means to patch the glass.
Here’s the needed part MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly and here’s the guide you’ll need to follow MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly图片
产品
$549.99
这个答案有帮助吗?
得分 0
添加一条评论
What model specifically? I think there are 21 MacBook Pro models that match the A1398 model number, you may wish to lookup yours by EMC NumberModel ID, or Serial Number for greater precision.
这个答案有帮助吗?
得分 0
评论:
As the OP did post the exact model I don't think we need to assume its a different system than what he stated: Mid 2014 15" MacBook Pro
完成的
添加一条评论
添加你的答案
Shawn Noor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 7
总计 384
