I can't install macOS on my MacBook Pro system.
Hi!
I’m having a problem with my MacBook Pro, I replaced the HDD for a new SSD and when I try to format the drive or install the macOS I get a lot of errors and I can’t install …
Things what I’ve tried:
- I change the hard drive flex
- I try with another drive
Already installed the macOS on another drive and put into the computer.
What can be the problem?
Thanks
— Sorry for my bad english, I’m trying to improve it.
Update 20/06/19
I solved my problem with another hard drive cable. To be honest i used this part number connector 821-1480-A and i dont have any problem, finally i install macOS Mojave. So i think this a strange problem…
Thank you all for the help and information about the issue!!
3条评论
You would get much better help if you described the error messages you are receiving. A photo of the screen with the error message would be even better.
由 AppleGuyPie 完成的
When im trying to install with recovery i see this on the console:
failed to verify installesddmg.pkg xar_verify failed
And when im trying to install with a usb i get somethin like this:
An error occurred when validating the installer data. the download is damaged or incomplete.
由 Bryan Formento 完成的
What systems are you trying to install?
由 mayer 完成的
